Railroad Line Forums - Distressing a MTL C&S coal car
[ Active Members: 3 | Anonymous Members: 0 | Guests: 229 ]  [ Total: 232 ]  [ Newest Member: PRRJim ]
 Shop Talk
 Rolling Stock: the Car Shops
Author Previous Topic: three bobbers for the C&V Topic Next Topic: Gloorcraft PRR N6B Caboose
jeyjey
Posted - 10/06/2015 :  3:04:35 PM  Show Profile  Reply with Quote
I distressed the first of my HOn3 Micro Trains Line C&S coal cars:
  • Tops of sides cut down with a hobby knife.
  • Insides and brakeman's footboard scratched with a stainless steel brush.
  • Insides and footboard painted off-white, and then stained with a mix of oak and ebony stain.
  • Iron straps and corner braces inside car re-painted boxcar red.
  • White lettering scratched with stainless brush.
  • White lettering smeared with pan pastel.
Jeff.
Country: Ireland | Posts: 386
Posted - 10/06/2015 :  3:13:02 PM  Show Profile  Reply with Quote
Coal and rain produce carbonic acid, which would cause the inside iron to rust.
Overall a great job, consider adding some road dust along the bottom of the car.
Country: USA | Posts: 8838 Go to Top of Page
jeyjey
Posted - 10/06/2015 :  3:44:06 PM  Show Profile  Reply with Quote
> ... consider adding some road dust along the bottom of the car...
Definitely. But I think I need to figure out the airbrush for that (it's been about 30 years since I last used one).
The truck in the background needs it even more (as it's a darker colour).
Country: Ireland | Posts: 386 Go to Top of Page
acousticco
Posted - 10/07/2015 :  01:32:09 AM  Show Profile  Visit acousticco's Homepage  Reply with Quote
The car looks great, as does the layout it's sitting on. I'd love to see more!
-Cody
Country: Canada | Posts: 1767 Go to Top of Page
Posted - 10/07/2015 :  10:08:26 AM  Show Profile  Reply with Quote
Or try some Pan Pastels, they work well for this kind of application.
jeyjey
Posted - 10/07/2015 :  12:30:04 PM  Show Profile  Reply with Quote
-Cody
He he... you've just seen about 1/2 of what is done.
The other 1/2 can be seen near the end of the Stub Switch thread (http://www.railroad-line.com/forum/topic.asp?TOPIC_ID=45882).
Jeff.
jeyjey
Posted - 11/29/2015 :  2:17:41 PM  Show Profile  Reply with Quote
I was holding off on Dave's suggesting of adding some road grime until I got the couplers swapped out for some Sergent Engineering Sharons.
Sure enough, the handling of the car rubbed off most of the white pan pastels I had applied for the washed-out paint.
So I pastelled it up again, added some road grime (using powder scraped from a Derwent pastel pencil), and sprayed it with matte varnish. The varnish also made most of the pastels disappear.
I thought "no problem", I'll just put it on a bit heavier. The second application of matte varnish, however, didn't have nearly as big of an effect, leaving me with a slightly caricature weathering.
My guess is that the first coat of varnish provided more tooth for the second application of pastels, but I'm not really sure. In any case, I'm happy enough to consider these "done" (apart from adding a full load to one, and a partial to the other).
Jeff.
Glen Haasdyk
Posted - 11/30/2015 :  01:58:10 AM  Show Profile  Reply with Quote
It looks very good and old. You are right about the matt Varnish it will add the 'tooth' you were referring to. Spraying with dulcoat will do the same
Country: Canada | Posts: 2517 Go to Top of Page
Railrunner130
Posted - 11/30/2015 :  07:15:42 AM  Show Profile  Visit Railrunner130's Homepage  Reply with Quote
My eye was distracted in the first few photos by the nice job you did on the truck!
Country: USA | Posts: 530 Go to Top of Page
