[ Active Members: 3 | Anonymous Members: 0 | Guests: 313 ]  [ Total: 316 ]  [ Newest Member: SandersReview ]
 Shop Talk
 Rolling Stock: the Car Shops
 Passenger car diaphragm discussion
jbvb Posted - 12/03/2015 : 11:57:48 AM
At a club where I was a member, diaphragms were referred to as 'derail-a-phragms'. At that time, even imported brass models rarely came with them installed, so it was all on the modeler's shoulders. Now, high-quality RTR equipment includes them, but there can still be issues, to wit those that led me to propose this topic.
4   L A T E S T    R E P L I E S    (Newest First)
k9wrangler Posted - 12/26/2015 : 10:42:48 AM
Interesting topic. I was at an ops session a week ago where that issue came up, just about 5 inches beyond being able to reach the cars in an enclosed area going into staging.
jbvb Posted - 12/26/2015 : 09:23:04 AM
Thanks, Mark. The Osgood-Bradley is stock, except for trimming the New Haven-specific skirting off the B&M car and adding window shades. The Plan 2417D parlor is brass sides, new 242 trucks and NERS A/C duct and detail parts on an AHM/IHC 12-1 body.
N2626 Posted - 12/26/2015 : 06:52:18 AM
Looks like you figured it out, good job! Another fix would have probably been to remove the non American Limited diaphragm and replaced it with an American Limited diaphram. I would think having different manufacturer's equipment might cause problems.
Very nice passenger cars, by the way!
jbvb Posted - 12/03/2015 : 12:12:05 PM
One of my passenger trains had regularly recently started derailing on a particular piece of track. When it happened, it was always the forward (as the seats are turned) truck of a Rapido HO scale Osgood-Bradley (American Flyer) coach. And only when behind a parlor car I'd built out of an old Rivarossi 12-1 Pullman. And only at one point where a decreasing radius spiral curve finally got down to about 36".
I checked and adjusted the track, adjusted the grade, made sure the trucks could tilt over irregularities, etc. etc. After spending quite a while looking at the wheels going back and forth, I took a look from above:
The corner of the American Limited diaphragm on the Parlor is hooked inside the Coach's diaphragm.
Rapido's diaphragm opening scales fully 6' 10" high. The AL diaphragm is much lower. Separating them farther didn't work, it would still hook occasionally. So I did this, after an idea dating back to the era of Walthers paper diaphragms and shirt collar acetate:
My jury is still out over whether this looks more or less conspicuous than the original, which covered the whole opening with clear plastic. But that's only an issue in 'going away' shots of models, and they will now stay on the tracks for my train crews.
Steam was generated in 0.14 seconds. Powered By: Snitz Forums 2000
